Has anyone installed one yet? I'm thinking about taking out the drivers side vent by the window to put the guage there!
Abyss Monotone Power Package All exterior lights upgraded to Piaa 60 Series Flowmaster, K&N Typhoon Autometer liquid filled oil pressure guage 5% Tint on all five rear windows Hurst Pistol Grip shifter, Piaa Sports Horns
I like having both of the vents on the drivers side. In the winter, you can have them heat up your hands while driving I have thought about an oil pressure gauge, but where to put it has kept me from really pursuing it. I don't want to give up anything in the dash for it. Somebody makes things that go on the frame between the door and windshield, but that's a bit too much "in your face" for me. I have been thinking lately about putting it in the top left corner on the dash, which would block even more light from the DRL sensor, but since it seems to always think it's dark anyway, probably wouldn't matter.Probably better to get an electrical gauge, I think it would make install easier. I put a pic of the oil pressure switch in http://forums.genvibe.com/zerothread?id=6395. If I put one in, I'd get a T to have both the stock switch and the new pressure sending unit together to use the gauge but still keep the idiot light. Haven't investigated the required plumbing though.In that thread, MadBill said "I installed my vacuum gauge in the flip-out compartment near the driver's left knee"I've also been thinking about taking a voltmeter and mounting onto a 12V plug and then just plug that in instead of the cigarette lighter.
I've been thinking about pursuing a DashPC kinda thing. ( http://www.dashpc.com If there are sensors that'll put out any sort of value, i'd connect it all up to a touchscreen..I swear..when I get the money, i'm gonna have a James Bond Vibe.. and trust me, no wires running everywhere.. Mostly nice and clean..and wooboy..somethin' to look at!If I had a million dollars...
I usually have that vent closed so it doesn't bother me to take it out, and Autometer makes the A-piller guage pod but nothing yet for the vibe. Just was wondering if anyone has done it and any major routing issues as I will use the mechanical type(more accurate, and faster response than electric)
Well today it goes in, the Auto-Meter pro comp 2 5/8 mechanical sender. I will post all pics and problems later on, but so far I test fit the guage and it fits perfectly where the center vent is/was, just up and to the left of the CD player!
When I had my heart set on a SC (before the $3K pricetag was official) I had thought of putting a boost guage in that vent. Here's a poor photoshop of it. Is this the vent you are thinking of?
So why'd you choose a Mechanical guage? Because they're cheaper?Personally, I'm not a big fan of running the plastic hose all the way to the guage.... if I were to do it I'd go for the electrical guages....And I am considering it.... these "idiot lights" are driving me nuts -- they don't really tell you anything.....
Actualy Carl I got the idea from you, I saw your pic about a year ago and thought waht a great idea! BTW Altus I chose the mechanical because of the reliability, it reacts faster than an electric and as long as you go slow and tighten your connections and route the tube away from sources of vibration it will never leak! I use copper line too as added protection from vibration caused leaks. I buy my parts as a Warehouse Distibuter so price isn't that big of a deal, I just want quality equipment for a fair price!Check out the install in the Tech Info and Do-It-Yourself forum!
I remember the good old days when all cars had all these important guages instead of the idiot lights. Many times I have thought that the NTSB ought to make real oil pressure, battery and engine temp gauges mandatory in automobiles. It is a safety issue as much as the soon to be required tire pressure indicators - it is unsafe to have a car fail in the middle of the night, in the middle of nowhere, or in the middle of a busy freeway. Cost would not be very much if it were standard equipment. Of course the NTSB has procrastinated in requiring safer power window switches too. And whatever happened to the idea of an inside trunk release?
Quote, originally posted by jake75 » And whatever happened to the idea of an inside trunk release? not sure if it's mandatory, but all GM's i've come across have it.ofcourse it's only usefull when the trunk is enclosed. so our cars don't need it.what makes a gauge more usufull? it's the responsibility of the owner to keep up with a cars' maintenance.the idiot lights don't come on after the issue happens but usually before it's too late.alot of car's still don't have a tachometer you know..
My ScanGauge won't indicate oil pressure, but it will just about everything else and it plugs into the ALDL port under the dash. It displays open/closed loop, intake air temp, coolant temp, ignition timing, mpg, mph, rpm, battery voltage, engine load and throttle position. It displays any four of these readings simultaneously in real time. In the photo it is set to display volts, intake air temp, mpg and coolant temp.
Quote, originally posted by mcgusto82 »not sure if it's mandatory, but all GM's i've come across have it.ofcourse it's only usefull when the trunk is enclosed. so our cars don't need it.what makes a gauge more usufull? it's the responsibility of the owner to keep up with a cars' maintenance.the idiot lights don't come on after the issue happens but usually before it's too late.alot of car's still don't have a tachometer you know..1. I'll check out the trunk release thing at this year's Auto Show - usually in March. 2. If idiot lights are adequate, why do few if any cars use it for the coolant temp? As for me, I would get a lot of comfort being able to look at gauges that indicated oil pressure and voltage. Anyone care to take a poll? Example - If it added $50 tot he cost of the Vibe would you like your idoit lights replaced with an oil pressure and voltage gauge?3. Most of us normal drivers, especially those that drive AT's, could live without a tachometer.
Personally I like having a tach, although I drove a friend's old Corolla for a while that didn't have one and I got used to it pretty quickly. As a GT owner, I think it would be very difficult to enjoy the car without blowing it up if I didn't have a tach, but that's a pretty special case. A shift light would probably perform 90% of the function of the tach.
