Of course I have read and re-read all the info and discussion surrounding the coolant on these boards.
SO is anyone clear as to what came in these 2009-2010 Vibes from the "FACTORY".
Was it Dex-Cool which all the GM and store service people swear it was, or was it PINK or some sort.
Is there any Dex-Cool actual pink, it is orange right? Or does it turn pink over time???
I have a 2009 Vibe, bought in 2015, now at over 120,000.
The coolant level in the reservoir just below low right now, so I was going to add some.
It is definitely PINK color. The GM place that has serviced it since 2008 said DEX-COOL pink.
I was about to check out of O-Reilly with a Zerex Pink for Toyota and the checkout person said no way, you want Dex-Cool, 'yes it's pink'
I get that and it is definitely NOT pink, it is orange.
Is it safe to assume that this 2009 still has the TOYOTA pink in it, and that I should add a Toyota Pink or like alternative?
I checked the service history and no apparent flush has been made. It still had the original battery from Toyota from 2008-2016.
If it is still running great, do I need to do a flush/change yet?
THANKS!
