New improved serpentine belt tensioner
vibe63
Post by vibe63 » Mon Jul 23, 2018 12:00 pm
Found this on Ebay. For those of you who have gone nuts with the constant noise and failure of the hydraulic belt tensioner, this is a blessing. The Vibe isn't listed..... yet. They list Corolla (98-08) and Matrix (03-08), so I was sure it would fit the Vibe. And it does - I installed it on my '05. I called them, so they're changing the listing to include 03-08 Vibe. The pin you see at the bottom of the spring is for shipping - it falls out once you compress the spring to install the belt. One year warranty from the seller. Here's the link:
https://www.ebay.com/itm/Super-Auto-390 ... m570.l1313
Re: New improved serpentine belt tensioner
Post by tpollauf » Mon Jul 23, 2018 5:18 pm
Nice find ... and a great price. Won't need one for awhile BUT when I start working on my project 2003 Vibe GT this fall, I'll keep this in mind if I need a new one. Thanks for sharing. Another reason this site is awesome ! ;)
Post by zbyers » Tue Jul 24, 2018 5:50 am
Vibe63, is this for the 1ZZ or 2ZZ? The belt tensioners between the two have slight difference. I'm not 100% positive if they're interchangeable or not.
Based on the curvature of it, it looks like it is for a 1ZZ.
1ZZ: https://www.monkeywrenchracing.com/prod ... ta-1zz-fe/
2ZZ: https://www.monkeywrenchracing.com/prod ... ta-2zz-ge/
Ruby- 03 Salsa, Ray[is]AWD- 04 Salsa AWD, Simon- 03 Silver "Faux by Four"
Raven- 03 Abyss GT, Neptune- 05 AWD, Robyn- 07 Stealth Gray Metallic, Mystic- 09 AWD
GenVibe on Facebook, Everything You Need To Know About Vibes, Great How-To Index
vibe63
Post by vibe63 » Thu Jul 26, 2018 11:44 am
Can't say for sure about the 2zz engine. The tensioners look pretty much the same. Mine's a 1zz
Update: the listing says it'll fit an Matrix XRS which, I believe, is the 2zz engine, so it should fit the Vibe.
Post by zbyers » Fri Jul 27, 2018 2:31 am
I'd be leery of it actually fitting the 2ZZ. I never compared my old ones when I replaced them, but I do recollect some difference that made me think they wouldn't interchange.
petervivian
Post by petervivian » Sat Dec 29, 2018 9:16 pm
Hydraulic system should have better damping compared to a simple spring system. This spring based tensioner may resonate at a certain rpm.
