Vibe is vibratin'
professorjedi
Vibe is vibratin'
Post by professorjedi » Mon Apr 30, 2018 4:22 pm
Hey all,
Ok so my 2010 Vibe AWD 2.4L has started to vibrate when idling in Drive, a little in Park, and none in Neutral.
I've recently changed air filter and cleaned the MAF.
OBD II reader is showing no codes.
RPMS with warm engine are:
PARK 790 - 817 slight vibration
NEUTRAL 790 - 840 no vibration
DRIVE and stopped 635 - 680 moderate vibration
Any thoughts?
Mike
Re: Vibe is vibratin'
Post by vibrologist » Tue May 01, 2018 6:07 am
Check engine and transmission mounts.
How many miles on your Vibe?
professorjedi
Post by professorjedi » Tue May 01, 2018 6:36 am
Hey vibrologist,
Thanks for the info. The mileage on my Vibe is 72,000.
Post by Caretaker » Tue May 01, 2018 4:19 pm
iridium plugs and Denso ignition coils. They are wear items and need to be replaced. Sometimes you don't achieve the 100,000 miles on these items. I changed mine out early. Car is purring like a kitten and drinking like a fish.
** 2007 Honda Fit Sport **
professorjedi
Post by professorjedi » Tue May 01, 2018 5:02 pm
hey caretaker... did u replace due to vibrations?
Even so, I think I'll probably do the plugs and coils anyway even if it does turn out to be the mounts just to keep ahead of the maintenance ;)
Thanks!
Post by Caretaker » Wed May 02, 2018 7:01 am
misfiring and arcing is common with failing ignition coils and manifests as a stuttering/shaking engine. This is a regular theme on the Honda Fit boards and may have something to do with harder working small engines. Anyway, I replaced mine as preventative maintenance. If I lived out in the countryside I'd probably forgo doing any preventative maintenance but in the big city, incurring a breakdown in traffic could mean the end of your life with people speeding by you and distracted driving. I do whatever it takes to avoid mechanical failures due to my own negligence.
