Hey y'all,
My vibe is a 2008 base with the 1zzfe engine and 5 speed manual transmission. The oil drain plug has started to strip out on me so I am going to replace the pan. I have looked up the part and aftermarket pans seem to run around 50-60 dollars in my area. My local junkyard has one but they are quoting me 72 dollars. I found one on toyotapartsestore.com, part number 121010D010. Is this the correct oil pan? If so I'll pry order it, thanks.
WestC4
