C59 Manual Vibes. What grade of Gear Oil do you use?
Capt.Vibe
Post by Capt.Vibe »
So just before the winter, last November to be exact, I decided to drain my gearbox fluid on my '10 Vibe 1.8l and refill with fresh fluid since the OEM fluid has been there since new. In the Owners manual it says to use the following...
GM Goodwrench® Synthetic Manual Transmission Fluid (GM Part No. U.S. 12346190, in Canada 10953477 — 1 quart) or SAE 75W-90 GL-5 gear oil.
So I went with CAD part #10953477 (At an outrageous $35/quart) which is a 75W-85 GL-4 spec fluid. At first, I didn't notice much difference but a few days later as it started to get colder the shifting was more stiff and difficult than before with the factory fluid. I could feel the synchro's grabbing in 1-2 and 2-3 shifts, it was butter smooth before and was never felt before. Through the winter on really cold mornings (-15c to -25c) the gear shift would barely move and a longer warmup was required before I could take off, and even then you could feel the notchy gear changes. It gets better as the car warms up after a 15 minute highway drive, still not as smooth as the factory fluid which was butter.
So I just checked a Corolla/Matrix owners manual. Sure enough a straight SAE 75W LV (Low Viscosity) GL-4 (not GL-5 as the GM manual suggests) is recommended. So I went to a Toyota dealer here in Montreal, they do not sell it, they get it in a 'drum' just for the service dept. They can't even guarantee the viscosity, as they tell me it just says MTF on it. :| A quick google search gives part numbers 08885-81007 and 08885-81001. Only alternatives I could find was FUCHS 75W FE SintoFluid, Castrol FE 75W and Ravenol 75W. None are sold here :|
So if anyone wondered what happened to your butter smooth shifts after a fluid change, now you know. Anyone else experience this? What spec fluid is everyone running in your manual gearbox?
2010 Red Hot Metallic 1SA
triz
Re: C59 Manual Vibes. What grade of Gear Oil do you use?
Post by triz »
Try the Amsoil GL-4 75w90 it will bring the buttery smoothness back.
dragon64
Post by dragon64 »
I've been using Redline almost since my 09 was new. I also drive in similar weather and road conditions as you.
2009 Vibe 1.8L Manual - DBW controller, Hydraulic engine damper, S/S brakeline retrokit,22mm solid Rear ARB, urethane rear coil dampers, Front strut bar with brake cylinder brace, PIAA 410 driving lights, PRM Intake Wilwood front brakes, Lexus hood lifts
In my 03 GT I used Pennzoil syncromesh and it shifts great. www.monkeywrenchracing.com recommends that or a blend of Pennzoil and Redline depending on how much "race" vs smooth shifting you want. http://www.monkeywrenchracing.com/index ... ath=25_342
