My 2006 Vibe is making a lot of noise that seems to be coming from the rad fan. Has anyone had issues with this before?
Thx
Spray with some ATF (automatic trans fluid) and let it sit on them for a day or two without running the car. It works better than actual penetrating oils (and don't even bring up WD-40 because that stuff is meant to repel water and is terrible at everything else). ATF is highly flammable, so I wouldn't recommend getting it hot on a fan motor.GDV wrote:The fan blades seem to have quite a bit lateral movement. The screws for the motor are very corroded, might have to replace the whole assembly?
