Hi all,
I have an 06 fwd with the 1.8 liter engine.
The timing chain broke and I have replaced the chain and gears including the vvt i gear.
Problem is after the install it still just wings over like there is no compression.
I have removed the cover again and all the timing marks are lined up correctly.
Anyone know what gives.
I was under the impression these were not a zero tolerance engine which is why I made the attempt in the first place.
I did not unlock the vvt i. This might be in error but the thing should still run right.
Thanks in advance.
