been having trans issues, from engaging into 1st then into second, all is well from second up, sometimes it shudders around 40ish, changed fluid with toyota t-iv or whatever it is, issue stayed the same. was told something about a solenoid, but im getting the code from the engine light they list in the recall and basically i think its the faulty pcm, toyota did issue a recall but my car was excluded due to it not being a 2005+ year model.
mine is a late 04 build and the pcm part number in the car is the one thats listed as faulty, am i correct?
pcm says 89661-01060
661X is the lot #
so then i found this.
Vehicles Covered by the Safety Recall
Model Trim Engine Trans
4-Door Sedan CE 4 Cylinder 1ZZ-FE 4AT / 5MT
Corolla ’05 – ‘08 4-Door Sedan LE 4 Cylinder 1ZZ-FE 4AT / 5MT
4-Door Sedan S 4 Cylinder 1ZZ-FE 4AT / 5MT
Matrix ’05 – ‘08 4-Door Wagon (Base) 4 Cylinder 1ZZ-FE 4AT / 5MT 4-Door Wagon XR 4 Cylinder 1ZZ-FE 4AT / 5MT
Part Number Action Part Number Action
89661-0112# Replace the ECM
89661-02K40 Replace the ECM
89661-0113# Replace the ECM
89661-02K41 Confirm the LOT Number
89661-02C0# Replace the ECM
89661-02K42 No further action required
89661-02C1# Replace the ECM
89661-02K50 Replace the ECM
89661-02C9# Replace the ECM
89661-02K51 Confirm the LOT Number
89661-02D0# Replace the ECM
89661-02K52 No further action required
89661-02D1# Replace the ECM
89661-02Q90 Confirm the LOT Number
89661-02D4# Replace the ECM
89661-02Q91 No further action required
89661-02D5# Replace the ECM
89661-02R00 Confirm the LOT Number
89661-02K10 Replace the ECM
89661-02R01 No further action required
89661-02K11 Confirm the LOT Number
89661-02R10 Confirm the LOT Number
89661-02K12 No further action required
89661-02R11 No further action required
89661-02K20 Replace the ECM
89661-02R40 Confirm the LOT Number
89661-02K21 Confirm the LOT Number
89661-02R41 No further action required
89661-02K22 No further action required
89661-02R50 Confirm the LOT Number
89661-02K30 Replace the ECM
89661-02R51 No further action required
89661-02K31 Confirm the LOT Number
89661-0Z04# Replace the ECM
89661-02K32 No further action required
Confirm the LOT number (if required)
Use the 9th through 12th digits
For OK LOT Numbers 7227 and higher:
- No further action required.
For NG LOT Numbers 7226 and lower:
- Replace the ECM.
^^^^ does that mean it needs to be replaced?
what does "For NG LOT numbers" mean?
Not Listed or something of the sorts?
