My CV joint came apart when I was removing the trans
so I'm assuming I can just add some grease and put it back together? I couldn't get the end out of the trans while it was in the car, but eventually got the trans out.
Thanks!
gtv237
Re: My CV joint came apart when I was removing the trans
Post by gtv237 »
As long as the boot didn't tear you can just put it back together. You will need to tighten the band once you're all done.
Thanks. I kinda thought so, since it came apart so easily. The boot looks fine so I should be good.
