'03 Vibe has been acting up for the past two months. Only 46K miles on it. Earlier on the engine would stall out and idle roughly to start.
Swapped a spark plug on the driver side cylinder (cylinder 4?) with no improvement. Then switched the spark plug coils and determined that one was bad and replaced one.
It did run better once it was running but would still cut out completely while driving at times. I bought a second coil code reader indicated that cylinder 2 was misfiring but that didn't improve things.
I let the car sit a couple of days and it then ran fine. The check engine light even went out and I thought I was good to go.
Two days ago I was driving along and the engine simply cut out. It wouldn't restart and I had to have it towed.
With my friendly mechanic, the most we could come up with in the codes was the Camshaft Position Sensor (which has been order and will be put in.)
But the problem may be deeper.
The weird part is when you turn the key on you can hear the injectors working, the Tach will show 600+ RPM and the dash lights up.
When you crank the starter, the dash lights go out but the tach needle still shows RPM and the engine is not running.
The mechanic asked is there some kind of "ECM" ? Power Relay, Fuses etc....
Anyone have any similar issues or insights?
I'll put the CPS in as soon as it arrives but unfortunately it seems like something else may also be required.
Thanks for any assistance!
