Finally have some time in the shop to fabricate a new exhaust for my car and I just bought a new tool a pipe expander. Actually I'm make 2 different set-ups.The stock 1.8L exhaust doesn't have a short extension between the 2nd cat and the resonator like the 2.4L cars so a slip joint is not possible from the cat back. Since I have to weld onto the 2nd cat anyway decided to fabricate a merge tube from sheetmetal and a short extension to make a slip join possible. The first exhaust system is just your average catback made from re-purposed Yonaka exhaust kit for the mufflers and basic bents and some additional J-U bents and straight pipe. The second exhaust will be a little different. I will be built on the De Laval effect where there is a strong low pressure zone behind a hot high pressure that creates suction in the exhaust as it progresses to the tailpipe. In place of your average everyday glasspack straight through resonator and muffler, I have a S/S Moroso Spiral Muffler. The reason for this is that it has a small diameter velocity tube down the middle keeping exhaust gas velocity high at low rpms but at high RPMs the hot gasses expand release heat and sonic energy creating a vacuum. At the back I'm using a Flowmaster serie 50 Muffler. Again using the muffler as and expansion chamber creating another low pressure zone. On previous cars I have achieved near zero to negative pressure in the exhaust system and at WOT have seen slight positive intake manifold pressure
2009 Vibe 1.8L Manual - DBW controller, Hydraulic engine damper, S/S brakeline retrokit,22mm solid Rear ARB, urethane rear coil dampers, Front strut bar with brake cylinder brace, PIAA 410 driving lights, PRM Intake Wilwood front brakes, Lexus hood lifts
Forgot to post this earlier. Did a baseline Dyno run on a friends dyno before chopping out the stock exhaust. My 1.8L/ 5speed my average pulling was a little over 118 whp. We were looking through his database of other cars he has tested and looked up a '12 Scion TC with a 2.4L / Auto and a '10 Corolla XRS also an Auto were only pulling 8 and 10hp more. Waiting for a day when he has free time to do my first "after" dyno runs.
BTW the air box was returned back to stock before the test.
