I have a 03 vibe gt that threw a bearing, replaced the engine and now the exhaust ports don't line up to the manifold, i believe the engine came from an 04 matrix XRS. Any help would be awesome
2000 Dodge Neon mtx 300k+ booger bushings,motor mount inserts. DD
2003 Pontiac Vibe GT 136k, stock for now. Wifes DD for now
If it is indeed a 2zz, the only issue I could think of is the injection ports. 2003 was the last year for the 2zz without air injection. This is a very simple solution, buy this kit from MWR, and just tap the holes in the head, and install the plugs. http://www.monkeywrenchracing.com/produ ... ts_id=2067
Also, what did you do with the last engine? If you still have it, I would love to buy it off you. I need a spare block to mock up mounting an awd transmission from a celica gt4.
Remove the heat shield if it is in the way. It's really tight back there, so it will be difficult.
Get a tap handle at a hardware store if you don't already have one. Put a bit of grease on the tap, and tap the holes. The grease will prevent most of the shavings from getting in the exhaust. Then just run the plugs in, and you're good to go.
