Hello there. I have a slight chirping coming from my clutch somewhere. It sounds like a serpentine belt but it goes away completely when I push the clutch. I figure I should just go ahead and replace everything while I'm in there. I'll need the pilot bearing (if it has one), the throwout bearing, the disc and the pressure plate. I read somewhere that you're supposed to replace all the bolts when you do the clutch. Is that true? If so I guess I'll need flywheel bolts and pressure plate bolts as well.
I'm planning on buying the parts online from a GM parts retailer. Does anyone have the part numbers? I cant seem to find them ): Its a 2009 1.8 5-speed.
