trying to sell my 06 awd tranny potential buyer has 03, i know the engine is all the same ands its still a U341F code trans so it will likely bolt up but i'm only seeing a 03-04 p/n a 04-05pm and an 05-06 p/n are these interchangeable or do sensors need to be swapped or is it nfg? any solid info would be appreciated so i can collect my $ with a clear conscious
03 Vibe GT JDM MR-S 1ZZ-FED swapped w/C60 6 speed - Starting Part out! - 230k mi
90 Celica Alltrac Awd Turbo ST205 swap Red - sold... Buy more parts BC I'm Buying her back!
01 MR2 Spyder Vibe 2ZZ-GE w/ Jdm C65 LSD Trans swap -sold
P.S. it worked fine, externally identical only had to swap the shift selector on front of trans due to different connector and the trans takes 4 qts of atf instead of 3
