09-10 GT header?
Digglesworth
09-10 GT header?
Post by Digglesworth »
I know there's a Megan Racing header for a scion tc that fits our 2.4L. Has anyone installed a header? I'm curious as to the issues we gotta deal with.... o2 sensors, cats, downpipe, fit issues, etc..... I want a header but I don't want to throw codes or fail emissions.... Is it possible???
2009 Vibe GT
Magnaflow cat-back - K&N Typhoon SRI - Tein S Techs - NGK iX's
5400k Xenons - Shorty Antenna - Curt 1.25" hitch
joshuaeb09
Re: 09-10 GT header?
Post by joshuaeb09 »
Hey Man,
Here's some more info than what I had PM'd you (just so everyone else can chime in or get the info) :
1.) It will fit, but its a little tight and I would use the gasket that comes with the header
2.) Since the pre-cat was in the OE manifold you will pop a p0420
a.) Can fix with a spark plug fouler mod, but it blows not recommended at all
b.) You can get an 02 sim which will fix the problem, but its pretty shady legally
c.) You can extend the 02 harness and install another cat welding in a bung after it
3.) Down pipe would be for a turbo install (post Turbo)
4.) If your thinking of a mid pipe I didn't look into it, but our exhaust config is a little off from the TC or XB so you might not have very good luck.
If you are worried about emission there are 2 kinds of testing OBD-II reading to check that you have no codes even ones that won't always pop a CEL. And then there'e the dreaded sniffer that will actually measure your exhaust gas output levels. I didn't have emissions testing in my area so I didn't really care, but if you do I wouldn't really worry about a header unless your prepared to get it sniffed and then see if you need to get another CAT etc. If you do go with a header and you have to get smoged make sure you run it like a bat outa hell (no chip/tune/etc. stock ECU strategy) for a few miles to get the remaining post cat heated up. That may allow you to pass your emissions depending on the state requirement.
2009 Silver Vibe GT AutomaticI/H/E/Unichip @ 93octaneMy Garage : http://forums.genvibe.com/zerothread?id=43521" onclick="window.open(this.href);return false; - Gone (Sold)
2005 Expedition Limited 2WD|4R75W 4SPD Auto|3.73 Gears|I/E|5Star Tuned@ 91|3" Lift/Level - Current Ride
Digglesworth
Well I just briefly read through the Illinois emissions site and they are going to a OBD test only. Got rid of the old "sniffer". So looks like the sim would be the way to go... Which sensor did you install the sim on? The upper(closest to head) or the lower? What pipe did you use between the header and cat-back system?
2009 Vibe GT
Digglesworth wrote:Well I just briefly read through the Illinois emissions site and they are going to a OBD test only. Got rid of the old "sniffer". So looks like the sim would be the way to go... Which sensor did you install the sim on? The upper(closest to head) or the lower? What pipe did you use between the header and cat-back system?
For future readers: The first O2 sensor monitors how the engine is running and comes before the cats. The second one checks catalytic efficiency and throws P0420 when efficiency drops below 85%. The second one is a simple O2 sensor that can actually be spoofed with a resistor and capacitor.
http://www.newcelica.org/forums/showthread.php?t=216641
Remember that you can overheat the resistor and capacitor until they no longer function, and of course this is all illegal unless you're only doing offroad.
TireToast
Post by TireToast »
How significant of an effect do you think the Megan Racing headers would have. Especially if I intend to have the ECU tunned?
TireToast wrote: Mon Mar 04, 2019 12:15 pm How significant of an effect do you think the Megan Racing headers would have. Especially if I intend to have the ECU tunned?
Probably minimal. I don't think there is anyone that can tune an ECU on the 09+?
zbyers wrote: Tue Mar 05, 2019 4:33 am
Orange Virus Tuning can and does.
Adding a header isn't going to do much other than make your Vibe loud and raspy (aka sound like crap).
