silverbullet wrote:i cant help with too much detail because i imagine your awd is different than my base i recently changed the manifold on. but i was also worried about breaking a bolt so for about a week and a half i sprayed all the bolts and nuts with pb blaster every night. seemed to help i didnt break anything. also use the shortest tools possible to eliminate the ability to apply so much torque. i did all mine with 3/8 drive ratchets. bigger tools seem to make it easier to break parts. also the small bolts on the heat shield were in such bad shape i could not get them off, so i just beasted it out and tore it off. its pretty thin metal, be careful sharp tho. good luck.
Thanks for the words of advice. I started regular blasts on the heat shield bolts yesterday. Never thought of the use of a smaller size wrench to minimize excessive torque. I was actually thinking of using an impact wrench on the lowest setting.
2003 AWD Vibe, 153K miles.
