Need a new clutch....
WhiteFiver
Post by WhiteFiver »
So I have a 2004 base Vibe with the 1ZZ-FE.f 170,000KM, and clutch needs replaced. I have a few options so far from searching around, but I'm seeing a lot of topics from 2006-2008, so I'm looking for some updated recommendations.It needs to be better than stock, so no OEM. These are the ones I'm looking at.CCI 2100 Stage 2 Carbon-Kevlar Clutch P/N: 16080-2100 (http://www.competitionclutch.com/produc ... php?id=300)ACT HD Stage 2 Clutch: http://www.prostreetonline.com/pnsku/tc2-hdss.aspExedy Stage 1 Organic Clutch: http://www.ptuning.com/html/It...=VibeWhat do you think will be better? Or do you have some more suggestions?
2008 G5. K&N SRI, 16x7 Akita AK-7, Painting, CCFL Projectors, tinted tails.2004 Vibe Base, 160,xxx KM, 37,xxx KM on motor
WhiteFiver
Bump.Anybody?
Re: (WhiteFiver)
Get the exedy stage 1! Should fit the bill!
2019 Ram 3500 4x4 CCSB srw 8HP75
WhiteFiver
Well, the clutch is done! Went with a 20% over stock holding power, and strangely enough, the clutch pedal is *lighter* than it was before. Oh well. I like it now . Friction point is right at the floor too.
