RPMS?
cp_stunna_2011
RPMS?
Post by cp_stunna_2011 »
my car is the base auto 2003 vibe. it seems that today the rpms was high before shifting andf while driving it seemed high as well. it stayed in between 2 and 3 (x1000) rpms when going 60-70 mph. what should it be at? is this where it is supposed to be? it doesnt sound like its revving high or anything of the sort it sounds completely normal, it could be just me but i dont think ti is normal.
Baby Blue
lovemyraffe
Re: RPMS? (cp_stunna_2011)
Post by lovemyraffe »
That seems normal to me.In my '05 base auto I run 2900 rpms going about 80 mph.
cp_stunna_2011
Re: RPMS? (lovemyraffe)
okay, any others?
Baby Blue
Guy in PHX
Post by Guy in PHX »
My 2003 base w/auto at 65mph is almost dead on 2500 RPM.
Just Passin' Thru
2003 Vibe/2009 Nissan Cube
Sublimewind
Post by Sublimewind »
did you tap the O/D button on the side of the shifter... I use it all the time to shift the Auto, like a manual... especially in the winter..
cp_stunna_2011
Re: (Sublimewind)
nope, we accidently snapped the connectors on the end of it that connect to the actual button and found no use in trying to reconnect it so it is always on, no annoying little O/D off light is anywhere to be seen, i find no use in reconecting it, but if there is please tell me.
Baby Blue
Old Tele man
Post by Old Tele man »
...our 2009 Vibe (base 1.8L with 4-speed auto) with OEM factory-installed P205/55R16 Goodyear RS-A Eagle tires:35 mph = 1.45K rpm45 mph = 1.87K rpm55 mph = 2.28K rpm65 mph = 2.70K rpm75 mph = 3.11K rpm85 mph = 3.53K rpm...which is about 24.1 mph for every 1000 rpm.
• 2014 Prius 1.8L eCVT
• 2009 Vibe 1.8L 4A
• 2004 Vibe 1.8L 4A
Sublimewind
Re: (cp_stunna_2011)
Quote, originally posted by cp_stunna_2011 »nope, we accidently snapped the connectors on the end of it that connect to the actual button and found no use in trying to reconnect it so it is always on, no annoying little O/D off light is anywhere to be seen, i find no use in reconecting it, but if there is please tell me.In the winter I used ALL of the gears in my auto tranny to help slow the car... Using the brakes in certain situations will get you into MORE trouble.. I like to hit the OD button to slow myself a little a lot of the time (i'm all manual by heart, I hate driving an auto, unless i'm in traffic/long trips)We haven't talked winter tires yet have we?? They are VERY important IMHO... VERY...
