Chirpping!
Platinum76
Chirpping!
Post by Platinum76 » Wed Mar 25, 2009 6:58 am
I have the most annoying chirrping noise coming from the drivers side rear of the engine. (05 base model) It only does it at idle. and more so in gear. however the noise will fade and sometimes stop if it idles long enough. Anyone had this problem ?
NUBlackshirts
Re: Chirpping! (Platinum76)
Post by NUBlackshirts » Wed Mar 25, 2009 7:29 am
Could it be the Variable Switching Valve? I know mine was more noticeable after I installed the K&N Typhoon intake.
'04 Frosty GT <---Click here!Tein S-Tech springs; Tokico HP struts;Progress rear sway bar; DC Sports strut tower bar;Scion TC wheels; K&N Typhoon intake;GG Racing ground wires; JAW voltage stabilizer;FilterMAG SS-250; Militec-1; Sirius Satellite Radio
THE VIBERATOR
Re: Chirpping! (NUBlackshirts)
Post by THE VIBERATOR » Wed Mar 25, 2009 10:50 am
It sounds like a small supercharger, correct? Especially under a full load
2003 Vibe Base - Sold2005 Corolla LE 5 speedcustom short ram air box6k HID kitIn memoriam of the Vibe, may you rest in peace:http://www.cardomain.com/ride/3168634
Platinum76
Re: Chirpping! (THE VIBERATOR)
Post by Platinum76 » Sat Mar 28, 2009 5:24 am
yeah "sounds" like a supercharger (dont i wish). lts only at idle. as soon as the rpms go up, even from turning the wheel it stops. and like i said it will fade the longer in idles. i noticed it last summer a lil bit and now its really bad, especially when i'm in a drive through or something. its really annoying >
Truckin1999
Post by Truckin1999 » Sat Mar 28, 2009 7:55 am
How many miles do you have? Do you have an auto tranny? If so check the fluid level and make sure its clean and doesn't stink. Sometimes the pumps will chirp when going bad.
-Sean Cummings--Crushed Blue Steel Motorsports-06' GT, Abyss, Leather, M&T, Tint, Roof Spoiler, Magnaflow Cat-Back, K&N Short Ram modified for ram-air, S-Tech's, 18" KV5 Wheels, SLP Ram-Air Hood, paint matched headlights, strut tower brace.Now Making Custom Vibe Sub Enclosures
Platinum76
Re: (Truckin1999)
Post by Platinum76 » Sun Mar 29, 2009 4:11 am
104k. and its auto, fluid is clean. i have drained and filled it about every 20 k. So if the pump is going, does that mean i'll need a new tranny, or is it something that can be repaired?
keithvibe
Post by keithvibe » Sun Mar 29, 2009 4:49 am
sure it's chirpping and not a Tick-tick-tick sound? If it's a tick-tick-tick-tick-tick sound that Mostly goes away.. that is normal that the vsv
Platinum76
Re: Chirpping! (keithvibe)
Post by Platinum76 » Sun Mar 29, 2009 6:52 am
no its definately a chirping/whistling sound.
Platinum76
Post by Platinum76 » Sun Mar 29, 2009 12:13 pm
and i just noticed that it does not make the noise at all while in reverse.
