Poor Man's Complete Performance Mod Guide for the 1ZZ-FE(Vib
Salsa Guy
Re: Poor Man's Complete Performance Mod Guide for the 1ZZ-FE
Post by Salsa Guy »
So people swear by and other swear at the "High Performance Cats". They have been know to trip CELS (P0420) and not last very long. If you are going to add a header a hi flow cat would give you more bang for the buck.
FYI there are 2 TRD SCs for sale on MO. They work without any issues or Mods on the 03-04 1zz Vibes and 03-06 1zz AWD vibes. Then can work on the 05+ 1zz vibes but require a TB adapter, different piggy back computer and Tuning. That is the simplest and cheapest way to add real power to these engines.
mntn-biker
Post by mntn-biker »
Salsa Guy wrote:So people swear by and other swear at the "High Performance Cats". They have been know to trip CELS (P0420) and not last very long. If you are going to add a header a hi flow cat would give you more bang for the buck.
Adding a SC, you would still want the header and a free flowing exhaust though, correct?
2003 base model
Salsa Guy
Post by Salsa Guy »
Yes the header will help. But these SCs are rare finds, all bolt on and can be put on in 6 hours.
What year is your Vibe?
mntn-biker
'03 w/1zzfe. So SC w/o the header and exhaust? Will the motor exhale ok then?
2003 base model
Salsa Guy
Post by Salsa Guy »
The TRD SC was designed for the stock Exhaust system. The only upgrade in size is to the intake piping, the stock air box remains. However I'm running a SRI with the SC and have no issues. Now if you upgrade to a header, hi-flow cat and etc you will see even more gains.
The TRD SC Kit will work on your 03 with no issues. AT or MT?
mntn-biker
MT (6 speed)
2003 base model
Salsa Guy
Post by Salsa Guy »
You are golden then.
Here ya go
http://matrixowners.com/index.php?/topi ... msearch__1" onclick="window.open(this.href);return false;
mntn-biker
Salsa Guy wrote:You are golden then.
Here ya go
Ummm.... yeah that's more than I wanna/can spend. I'm sure it's a rare find and would love to ($ no object) but don't see that fitting in the budget right now. I'll probably just put more of a free flowing muffler on this for now just to get me by.
Thanks for the info anyway though!
2003 base model
Salsa Guy
Post by Salsa Guy »
You need to pay to play. Most of these mods, IHE, would yield less than 20HP total and you are going to drop about $500-$700 in them. Of course they will set-up you up for the SC in the Future.
mntn-biker
Salsa Guy wrote:You need to pay to play. Most of these mods, IHE, would yield less than 20HP total and you are going to drop about $500-$700 in them. Of course they will set-up you up for the SC in the Future.
That's why I'm just going to hold off for now and just go with a replacement muffler. If I go SC n the future, I may not even go with header, exhaust, etc. if I don't need to. Would rather not have a noisy obnoxious exhaust. Would rather like to be a sleeper at the light instead 8-)
2003 base model
Salsa Guy wrote:The TRD SC was designed for the stock Exhaust system. The only upgrade in size is to the intake piping, the stock air box remains. However I'm running a SRI with the SC and have no issues. Now if you upgrade to a header, hi-flow cat and etc you will see even more gains.
Salsa, what if you get the TRD SC and also run an engine management computer? Although I think you have to anyway with the TRD because GM wants you to use "theirs."
Salsa Guy
Post by Salsa Guy »
Here's a DC Sports header
Salsa Guy
Post by Salsa Guy »
Not sure what you mean. I'm running "GM Performance" AT piggyback ECU now (really a rebadged TRD). For the 03-04 1zz-fe SC Kits GM Performance = TRD.
Now if your want to use a Greddy EMU/EMB or an AEM FIC piggyback you may pick up a few more ponies but most tuners will want you to use 2zz injector and delete the TRD 5th injector.
I ran both the EMU and AEM but had some issues with the tune on both but the EMU was better but more complex. If you have an 03-04 the TRD ECU (or GM Performance) is the way go.
mntn-biker
Yep, saw that too. For a little more $, 1 could get a brand new one.
2003 base model
Salsa Guy
Post by Salsa Guy »
Don't get the OBX header, they have know issues with cracked welds
Salsa Guy wrote:
lannvouivre wrote:Not sure what you mean. I'm running "GM Performance" AT piggyback ECU now (really a rebadged TRD). For the 03-04 1zz-fe SC Kits GM Performance = TRD.
GM was claiming the TRD one has different ECU settings, plus I read somewhere that the TRD one will not work on a Vibe without a piggyback.
I'm thinking I'll probably end up going with the turbo kit from MWR and a piggyback since by the time I can afford either, I will probably be out of college and the SCs will be depressingly scarce. :(
PS: I bought a new DC header for $216+shipped (via "or best offer") and it should be here tomorrow. WOO!
Salsa Guy
Post by Salsa Guy »
lannvouivre wrote:GM was claiming the TRD one has different ECU settings, plus I read somewhere that the TRD one will not work on a Vibe without a piggyback.
Now the 1zz TRD/GM Performance ECUs are piggyback computers and as far as I know can not be re-tuned/programmed. Therefore they are one trick ponies.
I sincerely doubt that GM would spend the money or the time to re-program these ECUs. The GM Performance AT ECU only had a PN Sticker over the TRD PN Sticker. BlueCrush ran a TRD SC with a TRD AT ECU on his Vibe with no issues and I'm running a GM Performance AT ECU on my Matrix with no issues.
The 1zz TRD/Gm Performance SC Kit will work fine on 03-04 Corolla/Vibe/Matrix and 03-06 4WD/AWD Matrix/Vibe (all are DBC). That my friend is a FACT!
Now it you strap this SC on a 1zz FWD 05-08 Corolla/Vibe/Matrix (all are DBW) then yes you will need a different piggyback and a TB adapter.
That is also a fact.
Salsa Guy wrote:Now it you strap this SC on a 1zz FWD 05-08 Corolla/Vibe/Matrix (all are DBW) then yes you will need a different piggyback and a TB adapter.
Thanks man. Mine's an '06, which explains why I remember the piggyback. I'd already heard about that adapter, made me super-excited when I read about it, even though I am an impatient college student and probably won't ever have those kinda funds.
mntn-biker
northvibe wrote:Quote, originally posted by BlueCrush »No problem, Lancer. I wouldn't bother with the TB spacer since you have a supercharger. It may be more of a hinderance than a help. If anything, you should get your throttle body bored out from http://www.maxbore.com" onclick="window.open(this.href);return false; for $100. So you can allow more air flow into the engine.+1 to the throttle body bore out. thats why I bought the TB from BC to get it bored. its stock at like 54mm or something and bored to 60mm.
If anyone is interested, I have an extra (original with ~120k miles) 1zzfe TB that I took off my '03 base and replaced it with 1 I had bored out by George @ http://www.maxbore.com" onclick="window.open(this.href);return false;. It was in fine working order when I took it off, just a little gunked up from over the years but I took some TB cleaner to it to make the inside look all pretty and stuff. I paid $95 for the 1 I had bored out so I'd like to at least get that out of this one. I would do $100.00 shipped. I would even offer to ship it to maxbore.com for you if you wanted to get it bored it. PM me if you are interested.
I have more pics upon request.
2003 base model
kowboydmac
Post by kowboydmac »
Most of those links in the OP aren't working nowadays lol
Anyone care to update what are some good places to get moderate bolt on's like these?
spartans21
Re: Poor Man's Complete Performance Mod Guide for the 1ZZ-FE(Vib
Post by spartans21 »
Does anyone have a beat on where you can find some aftermarket parts for the 2.4 GT model? 90% of all post on here are only applicable to the 1.8 L
From what I read, it seems like the 2.4 owners are screwed out of a lot of upgrades of compatibility.
I am also looking to do some cheap upgrades (everything outside of forced induction), but the only thing I know that I could find is the Magnaflow Cat back exhaust.
What about headers , TB spaces, any anything else for increased horsepower for the 2.4 L?
