Well it may have been a false alarm on the Lunati cams, but monkeywrenchracing.com has Crower cams in stock.
http://monkeywrenchracing.com/....htmlHere's some info direct from the page:The cams you've all been waiting for. These cams are ground from new cores for excellent quality and durability. They bolt in to the 1ZZ-FE cylinder head with no machining required.Several different grinds are available to suit your car's mods and your goals.Stage 1 is a great bolt-in solution for someone looking for a power boost for their daily driver.Stage 2 is a street/strip combo with a liveable idle and gains in the mid to high rev range. Stage 2 FI is for those with turbocharged cars.Stage 3 is a full race cam for those looking for maximum power. The Apexi Power FC is strongly recommended with stage 3 so that you can increase the rev limiter, tune fuel and VVTi, and get the most out of these cams.Stages 2 and higher require upgraded valve springs.Specs:Stage 1: 268/260 duration, .374/.347" LiftStage 2: 272/272 duration, .374/.374" LiftStage 2 FI: 262/262 duration, .397/.397 LiftStage 3: 280/280 duration, .393/.393 LiftDyno results coming soon.
