Need help on 2003 Vibe AWD rear mount removal
cmgreyhounds
Post by cmgreyhounds » Sat Jan 11, 2020 3:59 pm
It seems to be captive between the steering rack and the k-member. I'm just not figuring out how to get the (removed) out of there.
Lots of videos on replacing the mount for a FWD version, but the AWD is quite a bit different. Thanks in advance!
cmgreyhounds
Re: Need help on 2003 Vibe AWD rear mount removal
Post by cmgreyhounds » Sat Jan 11, 2020 8:19 pm
Well as it turns out there's no way but the hard way for this one.
You have to unbolt the steering rack and drop the suspension k-member to get the clearance to get the mount out. Also disconnect the sway bar end links first so the sway bar doesn't hold up the k-member.
Not a fun way to spend a Saturday, but there it is.
Post by zbyers » Mon Jan 13, 2020 4:34 am
First, welcome to genvibe. Home of the best group on the internet. :lol:
That's a bummer that you had to partially drop the front k-frame to get the rear engine mount out.
Are you replacing all of the mounts? Or working on something else?
PS: we like pictures..of your car, dog/cat, or the project your working on with your car. :D
'74 Thing, '79 El Camino, '83 VW Vanagon DoKa '91 Vanagon
(2) '03 Bases, '04 GT, '04 AWD, '06 AWD, '07 Base, '17 Frontier CCLB
