Passing emissions with check engine light on
chrisblues12
Post by chrisblues12 » Fri Nov 09, 2018 3:11 pm
The check engine light has been on my 2004 Vibe for close to 2 years. It is one of those b.s. codes that don't affect the car.
My emissions test will fail if the check engine light is on.
Any advice on how to beat the test?
Re: Passing emissions with check engine light on
Post by vibrologist » Fri Nov 09, 2018 5:40 pm
As far as I know P0BS is not an official code :lol:
What is the actual code you have not addressed in 2 years time?
Post by joatmon » Fri Nov 09, 2018 6:05 pm
My 03 has been throwing evap codes for years, and I have tried a few things but haven't fixed it. I live in an area where I don't have periodic emission testing, so it's been a low priority for me, but I understand what you mean by bs code that doesn't affect performance
Not sure there's a way to cheat the test, if there was it would depend on what specific code is being thrown.
It might come down to just having to fix the car
Post by andrewclaus » Sat Nov 10, 2018 4:39 pm
A few years ago in Colorado, my Subaru passed emissions with a knock sensor code. The seller assured me it would and it did. Not sure if that helps.
Post by zbyers » Mon Nov 19, 2018 4:56 am
vibrologist wrote:As far as I know P0BS is not an official code :lol:
I like that.. P0BS lol.
Would definitely need the codes to help out.
(2) '03 Bases, '03 GT, '04 GT, '04 AWD, '06 AWD, '07 Base, '17 Frontier CCLB
GenVibe on Facebook, Everything You Need To Know About Vibes, Great How-To Index
chrisblues12
Post by chrisblues12 » Tue Dec 04, 2018 2:32 pm
Here are the codes I am getting:
P0171 fuel system too lean bank 1
P0133 O2 sensor slow B1S1
Transylvania
Post by Transylvania » Tue Dec 04, 2018 4:30 pm
Had the P0171 code on the 2002 Rav4 and did everything the internet suggested: looked for vacuum leaks using starter fluid, cleaned all 4 O2 sensors with a torch, cleaned then replaced the mass airflow sensor, cleaned the PCV valve. Code kept on coming back. Took it to the local shop and they diagnosed it as fuel injector issue, since it was running lean.
Replaced all 4 injectors, cleared the code and happy motoring is back.
chrisblues12
Post by chrisblues12 » Tue Dec 04, 2018 4:53 pm
How much did that cost ya?
Transylvania
Post by Transylvania » Tue Dec 04, 2018 5:59 pm
Ordered the 4 OEM (Denso) injectors on eBay for $55 USD. Didn't seat them properly on first try (fuel dripping), but got them seated on 2nd try. Job took around 35 minutes each time plus the drive around to make sure it's correctly done.
The code I cleared with a Blue Driver code reader (Model LSB2).
