Replacing Valve Cover gasket..cure time?
Lambo50
Post by Lambo50 »
I plan on replacing my valve cover gasket tomorrow after I get off work early. I already have the gasket an such but curious how long should I wait before driving due to the Super Black gasket sealer? I know I will only be using the sealer in two small spots so does it really take 24hrs before I can drive again?
Re: Replacing Valve Cover gasket..cure time?
You need to leave it alone the full recommended time or you might wash the silicone gasket off with oil splash and have it relocate into a critical area and plug an oil gallery. It probably doesn't take that long, but they give you that long period so you will not have problems, or worse, a catastrophic error like what I described.
Lambo50
Post by Lambo50 »
lannvouivre wrote:You need to leave it alone the full recommended time or you might wash the silicone gasket off with oil splash and have it relocate into a critical area and plug an oil gallery. It probably doesn't take that long, but they give you that long period so you will not have problems, or worse, a catastrophic error like what I described.
Yeah the Ultra Black sealant states allow 24hrs for cure time. Just seemed a bit much. Plus with my busy schedule its hard to not have to go anywhere within 24hrs. I guess I will have to wait until I have some consecutive days off.
cptnsolo77
Post by cptnsolo77 »
Have you tried tightening down on the valve cover bolts ? I had a leak and re-touqueing the bolts stopped the leak. I have no new oil stains in my driverway for over a week :D
* Kenwood Excelon KDC-X597
* Polk DB651-Speakers
* Drop In K & N Filter
* NGK Iridium IX Plugs
