Well I finally got around to putting new brake pads and rotors on....
Video of 60 to 0 tests compared to stock... https://youtu.be/0g_GNjT2TcI
Unboxing them video... https://youtu.be/BNmdW4RdLZc
I should have got the powder coated calipers but I didn't. I did the bedding procedure per Powerstop and this morning
it sounded warped when little brake pressure was applied and when it was warmer outside on the way home from work
it still did it but not as loud/bad.
So I ordered all the calipers and if it doesn't fix the problem I'm screwed lol.
I don't think the rotors are warped it seems more like a caliper problem. The old rotors were jacked up and the wheel would shake when braking.
And now it doesn't do that.
