New Powerstop Brakes Finally
korax234
Post by korax234 » Mon May 22, 2017 4:47 pm
Well I finally got around to putting new brake pads and rotors on....
Video of 60 to 0 tests compared to stock... https://youtu.be/0g_GNjT2TcI
Unboxing them video... https://youtu.be/BNmdW4RdLZc
I should have got the powder coated calipers but I didn't. I did the bedding procedure per Powerstop and this morning
it sounded warped when little brake pressure was applied and when it was warmer outside on the way home from work
it still did it but not as loud/bad.
So I ordered all the calipers and if it doesn't fix the problem I'm screwed lol.
I don't think the rotors are warped it seems more like a caliper problem. The old rotors were jacked up and the wheel would shake when braking.
And now it doesn't do that.
TrickiVic
Re: New Powerstop Brakes Finally
Post by TrickiVic » Wed May 31, 2017 11:57 pm
Saw your video and it was good test. Your viseo also reminded me I needed new Rotors so I bought myself a pair on CARiD along with some aftermarket rims I have been wanting.
Post by vibrologist » Thu Jun 01, 2017 6:39 am
You would feel warped rotors, not hear them. If you had no pulsation in the pedal there should be no warp. In fact most warp is actually thickness variation rather than potato chip warp.
I cannot tell from the video what your "problem" is.
