That was my guess. If the install was done right and the bearing fails then the spindle must be damaged in some way.bams50 wrote:I had the same problem with my 2004 just this year. May be a couple hundred miles out of a wheel bearing. The problem turned out to be a slightly bent home. No vibration or anything, but it was a very slight run out. Put in a new wheel bearing with the new hub and it's been OK for over 1000 miles now.
