Check to see if the rear hatch glass is closed. It's very easy to hit the hatch release button on the remote and not realize it. Try pulling up on the hatch glass handle- if it the glass moves, open the hatch then close it again (gently, but firmly )Yamahammer wrote: 2. While driving, the door open light on the cluster comes on and the interior light flashes. It happens when driving on bumpy roads. I have checked all of the doors and none are loose. Shaking on them doesn't make the light come on. Is this a common issue, and if so, what's the fix?
That would be a useful guide if mine was an automatic, not so much with my five speed.MacGyver wrote:
4. This is one of the best guides I have seen for changing the tranny fluid in the 1ZZ engine. http://www.paulstravelpictures.com/2003 ... nge-Guide/ You'll need four quarts according to that.
If you have the recirculate button pushed in, it is possible that the door gear will stop ticking. When the recirc button is off, if the clicking starts up again, you'll want to remove the recirc door motor and move the plastic gear 1/2 turn. Or you can buy a new motor.Yamahammer wrote:I haven't noticed the ticking sound the last couple of times I have driven it.
Well my bad, sorry I don't have experience with the stick shift trannys.Yamahammer wrote:That would be a useful guide if mine was an automatic, not so much with my five speed.MacGyver wrote:
You can upload three photos to each of your posts here if they are less than 130kb in size.Yamahammer wrote:I don't have a photobucket account so it will be some time before j can get a picture of the car...Quick question, is there a way to change the temp display from Fahrenheit to Celsius? Thanks
Imgr, tinypic, etc. Lots of image hosting sites.Yamahammer wrote:I don't have a photobucket account so it will be some time before j can get a picture of the car ( And the bike). So far so good with the car. The only problem I see so far is that there is something wrong with the fuel filler vent. I have to fill at a trickle otherwise the pump clicks off. There are no check engine lights, so I'm not sure what the problem is yet. Quick question, is there a way to change the temp display from Fahrenheit to Celsius? Thanks
There are a few free apps you can use (I use Image Size--it gets the job done but isn't great), or as a quick and dirty method you can just email a picture to yourself and select the pic size when you email it.Yamahammer wrote:So far I have about 2500 miles on it, and it has been running great. I've been getting right at 33 mpg out of it. I tried to post a picture, but I don't know how to scale it down from my iPhone so it will attach.
