Hey guys,
There's lots out there about replacing the serpentine belt tensioner assembly on the 1ZZFE. Apparently the hydraulic cylinder sucks.
The hydraulic cylinder on my 2006 Vibe seems to be a-okay, but the pulley bearing isn't - it is noisy and runs loose and rough. The pulley with bearing (Dorman 419615) is sold at the usual suspects, but it is not clear how to remove the existing pulley. There is some kind of plastic cover, which may be integral to the pulley itself.
Does anyone know if this is bolted on from the other side, or if there is a removable cover to reach a fastener for the pulley/bearing? I'd much rather replace the $15-20 pulley/bearing than the $100+ tensioner assembly.
Thanks!
Scott
