Thank you for the TSB number and title! My daughter just bought her '06 Vibe and it had already had its ECM replaced long ago under recall. She was almost immediately after purchase complaining about the hard start issue once the car was warmed up .. I was just poo-pooing her away saying that's probably normal. Whod a thunk it?)
Here's my contribution back to the group.
This was hard to find (and then reformat!! Sorry.. some of the intents don't want to line up right, but its good enough to walk in the dealers door with.)
Engine Control Module: All Technical Service Bulletins
Engine Controls - Intermittent Extended Crank/Hard Start
TECHNICAL
Bulletin No.: 05-06-04-074C
Date: May 24, 2010
Subject: Intermittent Extended Crank, Hard Start, Engine Cranks But No Start When Engine Is At Operating Temperature (Hot Soak) (Reprogram Powertrain Control Module (PCM)
Models:
2005-2006 Pontiac Vibe
Equipped with 1.8L Engine (VIN 8 - RPO LV6)
Attention:
Before proceeding with the reprogramming procedure in this bulletin, the Vibe Programming Application MUST be downloaded and installed on the PC. Refer to Corporate Bulletin Number 09-06-04-006A.
Supercede:
This bulletin is being revised to update the text in the Correction section. Please discard Corporate Bulletin Number 05-06-04-074B (Section 06 - Engine/Propulsion System ).
Condition
Some customers may comment on the following conditions:
- Intermittent extended crank or hard start when the engine is still at operating temperature (hot soak). Engine cranks for approximately three seconds, starts, may misfire after starting, then clears and operates normally for the duration of the drive cycle.
- The engine cranks but will not start.
- The technician may determine that the scan tool fails to initialize with the PCM and diagnosis reveals no injector pulse or spark during cranking.
Cause
These conditions may be caused by the following:
- The PCM calibration may not be maximized for hot restart.
- The PCM may have experienced an internal fault.
Correction
- Review SI for the symptoms and conditions described above. Refer to Diagnostic Trouble Code (DTC) List - Vehicle.
‹› If SI does not isolate a fault, reprogram the PCM with the latest calibration available.
- Use a multiple diagnostic interface (MDI) for reprogramming and ensure that it is updated with the latest software version.
- During programming, the battery voltage must be maintained within the proper range of 12-15 volts. Only use the approved Midtronics(R) PSC 550 Battery Maintainer (SPS Programming Support Tool EL-49642) or equivalent during programming.
1. Logon to TIS2WEB. In the upper right corner of the TIS2WEB Homepage, click on: "?" which is the Help menu question mark icon.
2. The
Main screen will appear. In the left column of the Main screen, click on:
VIBE Programming Application and Calibrations.
3. In the right column of the
Main screen, a
bulletin number, symptom and calibration file table will appear.
Note
Some reprogramming files may also be identified by their corresponding bulletin number.
4. Select the appropriate calibration file pertaining to the
Model Year, Vehicle, and Symptoms as indicated in the conditions described in this bulletin.
5. A
File - Download box will appear. Select:
Pontiac Vibe Folder and then click:
Save.
1. Double click on the:
Pontiac Vibe Folder.
2. Double click on the:
.zip file that pertains to this
Bulletin.
3. A Win-Zip Dialog box will appear.
4. Highlight the:
.cuw file, then click:
Extract.
5. An Extract - C:\ Dialog box will appear.
6. Select:
Pontiac Vibe Folder. Click:
Extract.
7. When the file is saved to the Pontiac Vibe Folder, close the:
WinZip Dialog box.
6. Double click on the:
CUW icon on the desktop to access the
Vibe Programming application.
OR
Click on the:
Start icon.
7. Select:
Programs.
8. Select:
Vibe Programming Application.
9. Select:
Vibe Programming.
10. The Calibration Update Wizard-Screen S701-02 box will appear.
1. Click:
File Open.
2. An Insert disk box will appear. Click:
Cancel.
11. The Calibration Update Wizard-Screen S701-12 box will appear.
1. Select:
Desktop in the:
Look in field.
2. Select:
Pontiac Vibe folder and click:
Open.
3. The
Look in field will change to:
Pontiac Vibe.
12. The Calibration Update Wizard-Screen S701-06 box will appear (Connect to Vehicle).
1. At the select
MDI or J-2534 device Tool, select:
ETAS MDI in the
drop down menu.
2. Click:
Next.
13. The Calibration Update Wizard-Screen S701-08 box will appear (Establishing communication with the vehicle). The Device Explorer box will appear, listing all the available MDIs.
1. In the Device Explorer box, select the:
MDI that is configured to the PC and is connected to the vehicle.
2. Click:
Next.
14. The Calibration Update Wizard-Screen S701-09 box will appear (Calibration Selection Confirmation).
1. Review all of the information in this box.
2. Click:
Next.
15. The Calibration Update Wizard-Screen S701-47 box will appear (Verify Calibration ID Numbers).
2. Click: the
old calibration under the
Target Cal ID column.
3. Click:
Next.
16. The Calibration Update Wizard-Screen S701-14 box will appear (Vehicle Preparation).
2. Turn OFF the ignition.
3. Click:
Next.
17. The Calibration Update Wizard-Screen S701-15 box will appear (Prepare for Reprogramming).
2. Turn ON the ignition, with the engine OFF.
3. Click:
Start.
18. The Calibration Update Wizard-Screen S701-17 box will appear (Flash Calibration Update in Process).
Wait for the update process to complete.
19. The Calibration Update Wizard-Screen S701-22 box will appear (Flash Calibration Update Successful).
3. Click:
Next.
20. The Calibration Update Wizard-Screen S701-23 box will appear (Prepare for verifying vehicle).
2. Turn ON the ignition with the engine OFF.
3. Click:
Next.
21. The Calibration Update Wizard-Screen S701-25 box will appear (Establishing communication with the vehicle).
1. The Calibration Update Wizard will verify the calibration that is currently in the vehicle.
2.
Wait for the process to complete.
22. The Calibration Update Wizard-Screen S701-26 box will appear:
Programming Successful!.
1. Verify the calibrations from the:
Before Update and
After Update columns.
2. Click:
Print or
Finish to complete the programming event.
Warranty Information
For vehicles repaired under warranty, use the table.
This TSB is coded
Labor Operation: J6354
Description: Reprogram ECM
Labor Time: 0.4 hr
Cheers everyone!!
Getmoresoon
