NICE!! any pics? how hard was it to get the plastic ties thru the rad and condenser to attach to front of condenser? did you need to loosen fan to fit hand in there. i still havn't found my fittings needed to install mine. by looks of pic from your link your cooler doesn't have the fittings like mine. hoses attach right to cooler nipples. wish mine was that way.lannvouivre wrote:I just installed http://www.amazon.com/dp/B000C39CL8/ref ... W4UGUY1994 for my trailer antics. Just need to install the lights harness.
Yes. The bottom line from the transmission is the return line. I started the car up with it unhooked and spewed about two quarts into a bucket in about ten seconds. I removed the fan and overflow for easy access, just remove the top two 10 mm bolts and unhook the hose from the radiator cap's little relief valve, then pull straight up. Much easier that way. If you leave the shroud in, it's a major pain cutting the little thru-clips.tpar1220 wrote:NICE!! any pics? how hard was it to get the plastic ties thru the rad and condenser to attach to front of condenser? did you need to loosen fan to fit hand in there. i still havn't found my fittings needed to install mine. by looks of pic from your link your cooler doesn't have the fittings like mine. hoses attach right to cooler nipples. wish mine was that way.lannvouivre wrote:I just installed http://www.amazon.com/dp/B000C39CL8/ref ... W4UGUY1994 for my trailer antics. Just need to install the lights harness.
heck... i may just order one like yours and keep the one i have for my olds. oh... was i correct in thinking the return line is bottom?
Grill insert??tpar1220 wrote:i typically cut up a piece of rubber hose and put between cooler and condenser on both ends for protection. so how did the grill insert "pop out"? i was looking it over and didn't see how that came out.
Grill insert??
i watched a video on you tube on removing the a grill on a pontiac G6. i assume the vibe would be the same.beemerphile1 wrote:I mounted it in front of the condenser/radiator after popping out the grille insert.
