Hi all, I'm in MI and planning on buying a 2004 vibe that has been driven up here mostly. I was wondering if Vibes tend to have body rust problems in the same areas. Thanks,
Paul
vibolista wrote:If the Vibe in question hasn't had an accident, it should be good. The lower cladding keeps the paint that covers the metal from getting chipped by rocks or road debris, so even if dirt and salt gets in there, it shouldn't be able to find bare metal to oxidize.
It's is very uncommon to see even the worst kept Vibe's with rusty panels. I live in a "Salt them roads crazy" state and you don't find older rusty Vibes. There are a lot of Vibes here. They make great Winter cars when you install a good set snow tires on them.
To be on the safe side, look around the inside of the open doors, around the open hood, rear hatch and the opening rear window. Make sure any rust in those areas gets treated and painted so it doesn't spread.
I've had mine since '08 and haven't seen any rust. Some engine bay bolts are prone to rust here and there, but that shouldn't be a problem. If the Vibe has steel wheels, they will rust. Clean em, sand them off well, prime them with rusty metal Rust-Oleum, and then cover them with gloss or semi gloss Rust-Oleum and they should be good for years. The factory paint thickness on those steelies was micronic. My son's steelies were completely rusty, and I refurbished them on a couple of warm dry days. Easy stuff to do, and they never rusted again, even doing snow tire duty for 6 years and getting minimal care.
Take some pictures of this Vibe when you get a chance.
Pontiac thought grey cladding was the bomb.Nasmfell wrote:Interesting GM decided to use body cladding while Toyota did not
Pontiac thought grey cladding was the bomb.lannvouivre wrote:Nasmfell wrote:Interesting GM decided to use body cladding while Toyota did not
