Yep. The 2009-2010 Vibe AWD and GT (Matrix AWD and XRS) have Independent Rear Suspension, while the 1.8L & 2.4L Bases do not, so they will have different rear struts depending on which model it is. The front struts should all be the same.lannvouivre wrote:For the second generation models, I'm not really sure which trim levels have independent rear suspension. As long as it's the same trim level and you only match FWD to FWD and AWD to AWD on the second gens, you're fine.
