On the Club ScionTC forum there is a guy that thinks his 2008 TC has a headgasket issue and a person at the bottom of the post talked about the headbolts stripping
http://clubsciontc.com/forums/maintenan ... -tc-40760/" onclick="window.open(this.href);return false;
But I find no others after 2006 with that issue
There is also a TSB on 2002-2006 2.4l engines
TSB 01507, NHTSA #10021542, Dated April 6 2007.
Coolant Loss on 2002-2006 Toyota 2.4L, 2AZFE engines
The following information concerns the loss of coolant on some 2002-2006 Toyota 2.4L, 2AZFE engines. The location of this condition has been noted at the rear of the engine where the cylinder head bolts to the cylinder block.
It has been reported that stripped head bolt threads have been found on some of these engines during tear down. When the two rear head bolts lose their clamping ability they allow coolant to seep out at the rear of the cylinder head.
To repair this condition, engine builders report using thread repair tooling used for various GM engines. Specifically, Cadillac 4.6L engines use the same threaded head bolts (Figure 1). The head bolts for this Toyota engine may be reused if they are not damaged and meet the following length specification.
Using a vernier caliper, measure the length of the head bolts from the seat to the end.
Specified bolt length: 6.350˝ to 6.465˝ (161.3 mm to 164.2 mm). If the length is greater than the maximum, replace the bolt.
I also read that Toyota made some changes in 2007 to the 2.4l engine in which the engine was revised and strengthened.
Look at the botton of the first page of this article by C&D about the 2007 camry
http://www.caranddriver.com/reviews/200 ... -road-test" onclick="window.open(this.href);return false;
As to what was revamped, I cannot say because I don't know.
However it seems that something was changed because I have not heard anything about head bolt issues on 2007- present Toyota 2AZ-FE 2.4l engines. There should be a lot of 2007-2009 2.4l engines hitting 100,000-200,000 miles by now and in the those years that engine was in Camry's, Vibe(2009), Matrix(2009), Highlander,RAV4, XB, TC but nothing has come up on them.
I guess that issue was fixed so just enjoy your Vibe.
I will say that the issue you should be looking at is the water pump. Toyota 2AZ-FE(2.4l) engines are known for going through them. The easiest way to see if you need to replace yours is to look at the underside of the hood and if there is a pink/red/green or orange(depending which coolant is in the car) line on the area of the under hood that is above the belt/waterpump because a leaking water pump slings coolant onto the underside of the hood
