with genvibe help i completed the job in 1 hour its easy, remove glove compartment & 1 foot long metal support arm you need a 20 inch extenchion & 10 mm socket to remove nut at firewall to reinstall use tape on nut in socket so it doesnt fall off befor it gets tight next to damper its in the way remove air bag 3 bolts get 7/32 micro wrench & 7/32 1/4 drive socket & wratchet & its done its tools correct ones, i got them at flea market well the mini 7/32 wrench $1
