dash thumping question
JerBear
Post by JerBear » Fri Mar 09, 2018 5:28 am
I have replaced the door actuator motor already and it would appear that they sourced the new gears with an even softer cheese (Bree?) and two years later it is thumping again! GRRRR anyway what would unplugging the actuator do if I couldn't care less about recirculation as a setting? I am assuming all it would do is de-energise the actuator and allow the damper door to stay in place where ever it is and stops the thumping.
The space is very cramped and made me say unkind words the last time i replaced it, I would like to forgo that again as well as buying a crappy replacement actuator.
Re: dash thumping question
Post by tpollauf » Fri Mar 09, 2018 6:31 am
Wow ... that S U C K S :x Just curious as to which brand/model you purchased when you replaced it two years ago? I'll be doing this exact repair to a 2004 Vibe GT that I recently picked up. My experiences driving this Vibe back from Florida (1800 nice relaxing miles) was that the actuator door needs to be powered open (does not stay open by default) otherwise you start fogging up your interior. Had to"crack" open the windows several times to get fresh air in the car so I could see out the windows!
JerBear
Post by JerBear » Fri Mar 09, 2018 3:28 pm
The brand I purchased was a Dorman, Got it from RockAuto I may try the old switcharoo on the original gear to the side with good teeth?
Post by tpollauf » Sun Mar 11, 2018 10:00 pm
Finally got around to changing mine out earlier Sunday. Yeah it was a B I T C H mainly for the one screw at the very top :x Here's the classical pic showing the missing teeth. All is back to normal now. Big thanks to others here on GenVibe and even a few You-Tube videos which helped clarify the process! ;)
