dewaker wrote:It was the daily driver of a corvette owner. I guess he used it only during the winter.
Sounds about right for someone from Bowling Green, KY.
Congrats on the Vibe! It's awesome that you found one with such low mileage. I was in such a rush to scoop up my '03 GT that I ended up with one that had a ton of miles. It was definitely a love-at-first-sight deal because it is the perfect car for me (quick, fun, useful, affordable, and at a local dealer). Getting one that's that young would be a major score.
Have fun with it! If you want a quick and cheap mod that will make your shifts feel even better, look for some brass shifter cable bushings. They should be under $30 and installation is relatively painless. I had some problems getting one of the old bushings off (the side-to-side movement) but the front-to-back swing bushing was easy. It makes a noticeable difference in accuracy and fun. As far as cost effective modifications go, the bushing swap ranks way up there.
Finally, welcome to the forum! You have a slick looking Vibe with an odometer that is sure to make a lot of people on GenVibe green with envy.
All the best,
LKS
